    • Avatar de Trafor
    • Durabilidad Defender Puma
    • 19 Ene 2022 23:56
    • Rompecabezas.
    • 19 Ene 2022 22:46
    • Avatar de Landairu
    • 19 Ene 2022 22:40
    • Micricat land Rover
    • 19 Ene 2022 20:25
    • Ruido metálico
    • 19 Ene 2022 20:09
    • Avatar de Ed153
    • 19 Ene 2022 18:36
    • 19 Ene 2022 14:04
banner Eigasbanner storm4x4
discovery kalimantan 96 en venta 30 Oct 2013 19:53 #703042
No está definida la ID de la APP eBay en la configuración Kunena
mi ingles pésimo por eso no traduzco
Hi Welcome to our Listing
Here we have our Camel Trophy Discovery 300Tdi Kalimantan 1996 event
The disco has done 110334 miles
There is an uprated inter-cooler and silicon pipes
New battery on passenger side fitted 2012
New springs, shocks and poly-bush kit all round fitted
crank seal,Cam belt, tensioner,idle pulley, crank pulley change at around 90k
event vhf radio fitted in rear, Codan antenna tuner also in rear
spare fan belt
175a Anderson connector running to rear for trailer + 7pin connector
mobile storage drawer in rear/2 side panions + storage containers
BAD POINT
front A frame passenger side at bottom near sills could do with
attention, Roof lining is a bit saggy
MOT due 2/3/2014 TAX March 2014
This car was the event Managers car in 1996.
It was driven by Nick Horne. It is seen on both video and in pictures.
We have owned it for 11 years and looked after it to the stand it is today.
It has brought us a very wide selection of friends and enjoyed our time spent with the Camel Club both at shows, events and holiday we have had in it.
also sun visors and rear door card have been singed by Camel trophy competitors and crew
I,ve probably missed something
feel free to send Q,s
inspections welcome
can email more pictures if needed, No time wasters please
we are open to offers just email, serious offers/people only please
collection on cleared funds or cash
or call me on 07811100646,
I am abroad from time to time so leave message I'll call back
UK BIDDERS ONLY
Also Advertised else were
Any parts etc on the discovery will not be sold separate
Payment to be received within 7 days unless
we have spoken before hand
el enlace
  • BOTICARIO
